Gear lube question
Gradywhite3535
I have a 1975 6hp Johnson. Is there suppose to be a gasket for either the drain or vent screws ?
Joe Reeves
Re: Gear lube question
The drain and oil level screws........
If the underside of screw head is cupped, there should be a O Ring.
If the underside of the screw head is flat, there should be a white nylon washer.
Gradywhite3535
Ohhh no. I just checked and i don't see either. I changed gear lube today and mannnn was it nasty looking. I hope there isn't any water getting in. With this pic do you see anything wrong with the color? And would u be able to tell me what number the of the white nylon washer. My screw is flat. Thank u very much
OEM Parts
boobie
White nylon washer, 311598............
Joe Reeves
I don't detect any water in that picture... just black gearlube.
kfa4303
Banned
+1. It actually looks pretty good. As long as it's not white/milky you're ok. You should have a small, white, nylon crush washer for both the DRAIN and VENT screws as well. Be sure to use 80-90w hypoid, outboard gear oil. You should be able to find it at most boat/auto/wal-mart stores. They should sell a small hand pump to go with it as well.
