Gear oil change
bijou22
hi - i have a volvo penta 4.3 with cobra sx drive unit and am about to change the gear oil, the only problem is trying to get the damn drain plug off. Can i suck oil through fill plug and then <br />re-fil
Don S
Re: Gear oil change
Nope, you have to get the drain plug out. Go to your local automotive store and get an impact screwdriver. They work wonders on those plugs.
texsun
Re: Gear oil change
Last year I was going to attempt the gear oil change and use my impact screwdriver. Broke the bit on the screwdriver. Let the shop do it. Do the shops have a big bit for that cobra/sx drain screw or is it a special tool?<br /><br />Mark
Don S
Re: Gear oil change
I purchaced mine from Snapon about 10 years ago and it does just fit the heads on the SX, Merc, and OMC plugs. But 1 guy here had a larger bit from NAPA that he uses all the time.
KRS
Banned
Re: Gear oil change
Don S knows his stuff, it's good advice.
bijou22
Re: Gear oil change
Great advice yet again. Gave it a smack with an impact and its sorted.Cheers
