drobertsobx
Thread starter- Joined
- Nov 1, 2008
- 74
hi,
I just finished DE-winterizing my 1996 Force 75HP (Fogging oil burn out and change gear oil). I left the motor down to drain out the water and was about to raise it back up onto the support when I noticed on the bottom skeg there was a couple of drops of oil. I removed the prop and ran the motor in fwd and rev for about 10 minutes and could not see any leaks. I dried off the motor and let it sit and about an hour later I checked and again I had a couple drops of oil. Looking closer it appears like it is leaking around the bearing carrier... I looked at the manual but it does not list a gasket in the schematic.
Has anyone else had an issue like this or could someone recommend how to fix this issue.
Added Picture looks like the left side and the oil is dripping from the bottom Carrier plate bolt.
Schematic:
Thanks in advance
--Don
Schematic:
Thanks in advance
--Don
