Gear oil leak
Rob Laz
Boat: 2010 SeaRay I/O 17 1/2 feet
Engine: Mercruiser 3.0 Alpha 1 Gen 2
I noticed that gear oil was leaking out of water vents on the lower half so when I removed the lower half and in process of changing the impeller, I noticed that the oil seal carrier, carrier compartment, impeller and impeller housing all had gear oil (for some reason I cannot upload pics). Before I change the impeller and do a pressure test, could this be a leak somewhere near the oil seal carrier or the carrier itself?
Rob
Rob Laz
I will look there. Should there be lube oil in that carrier assembly compartment and impeller housing?
No and those parts mentioned previously is what keeps the water and lube separated
