Gear Oil leaking around Bell Housing Gasket?
bavedoggs
Have you tried refilling the reservoir with the drive off, to see if the dribble valve is closed when its button isn't depressed?
could you explain to me what you mean or what This would look like? I can’t visualize it
bavedoggs
Ayuh,..... Put a new gasket on the top vent screw,.....
New gasket on the top vent screw? Can you explain this to me? I mentioned drive oil was around the bolts on the bell housing, what/where is the vent screw?
thanks
Ayuh,..... That valve is just a plastic assembly that slips into an aluminum hole in the housin',....
Grab it, 'n Pull it out,.... then clean, 'n inspect,....
thanks
Ayuh,... a couple inches or so down from the top of the drive, port-side is the Vent Screw,.....
If the drive is trimmed up, 'n the vent leaks, gravity brings it right down to where yer seein' the oil,....
bavedoggs
Hmmm. The vent screw, isn’t that on my starboard side? According to the pics I attached, I’m assuming the screw you speak of to be on the starboard side on the face of the bell housing. I’m seeing more of the leak on the port/passenger side of the bell housing. Am I confused?
thanks!
bavedoggs
Disregard, I know what your talking about. You said vent was on the port side, I thought you were saying the dribble valve was on the port side.
so pull the dribble valve out, clean it up, etc...?
sounds good-I’ll give it a shot.
JASinIL2006
I think Bondo is on to something. Make sure that plug has a gasket... looks like a washer.
bavedoggs
Thank you all for the input. I serviced the drive this weekend and replenished the gear oil, all new gaskets, etc.... I did notice that the vent screw had 2 gaskets in there. Not 100% sold that was the issue, but none the less everything is put back together and ready to hit the water. Ran it on muffs for a while and went through the gears, there were no noticeable leaks or problems. Time will tell.
