84 115johnson newbe
Thread starter- Joined
- Jul 22, 2013
- 31
I have a 85 Johnson 115 that seems to be leaking gear oil from under the seal on the prop shaft itself. I removed the prop, and the seal on the shaft looks to be much dryer than the bottom of the housing. I haven't ran the engine on the water yet due to my "distrust of the facts" from the seller. It has been taken apart in the past, and I can tell that the assembly has been taken apart from the excessive amount of sealant and markings around the lower gear casing. There was only about 8 oz of oil in it, and about the same of water. Any thoughts?
