gear oil path bottom to top MR drive
brucec
This may be a dumb question but now that I have the upper and lower units separated to replace water pump its not obvious to me how the gear oil traverses the water pump area to get from bottom to top. Did I lose an O-ring along the way? The splitting of the drive was really tough because of the white corrosion powder around the bolt shafts.
brucec
The manual exploded view shows an oil seal right by the water pump on the flange. That must be it. I'll go looking for it.
In manual 6, page 3B-56 is item "b" which is on the starboard side edge of the housing, that is the seal and oil path
