Re: Gear Ratio and Distributor differences..Cobra, ,Merc
Well Stan,<br />I admit I didn't follow your thread on the OMC Misses when trimming, Because it's OMC.......<br />But, After reading thru it, I think Don just Nailed the issue a couple posts above this 1.......<br />Where is the Power Tap for the Trim on your OMC ????<br />I think it's Not coming from the Battery, like a Merc., I think it's coming from the Ing. Circuit.. This will Overload the circuit, causing the stumble.... Feed it from the Battery......<br /><br />Now, back to the HEI,<br />(A little FYI, Sparks can Only Fly in a Straight Line)<br />Dist.s,+ Alt.s
Must be Vented...... With all those Sparks flying around inside it, theres a build up of Ionized gases.. These Must be vented...<br />Venting is achieved by 1 of 3 methods.....<br />A) Screens.... Fine Screens are used in Dist.s,+ Alt.s... The screens will be in the Base of the Dist.,+ in All the vents on an Alt.... These screens are Grounded to the body of the unit....<br />When a spark tries to leave by way of a Screened Vent, it Can't pass through the Little Hole in the screen, because it Grounds out on the Screen, Inside the Dist., or Alt.....<br />B) Some Marine Dist.s use a little Brass Elbow in the Cap...... These work on the principle that Sparks Can't fly around Corners.........<br />C) Others use a little High-Hat vent... Same principle.... Sparks Can't turn 90*, much less 180*.........<br />BTW,
Don't , I repeat,
Don't Glue the Dist. Sealed Closed.........<br />The Build-up of the Ionized gases will cause All Sorts of Problems............... <br /><br />That covers the Dist.,+ Alt......<br />Starters are slightly different....<br />The older starters that we're all familiar with have an extra "Plate" inside.... This Plate mounts Between the Motor part,+ the Bendix drive part of the starter....... A very expensive plate, But it's the only difference........<br />If you up-grade to 1 of the New High-Torque Starters........ Automotive,+ Marine are Exactly the Same......... The Motor is Already Isolated, by the gear-reduction drive.........<br /><br />And, of course the Carb.........<br />Marine Carbs have the Float Bowl vented Into the bore of the Carb, rather than onto the manifold..... If it overflows, it'll dump
Into the motor, Not
Onto the motor...........<br /><br />The Merc. T-Bolt system is about the Best thing going.......<br />Relatively Simple.....<br />Dependable......<br />And, Good to about 6000RPMs........<br />
If the above is not an insurmountable issue..then what about the spark interruptor. ...How is it wired to the ignition
It's quite Simple............<br />When the Switch is activated, it Grounds Out the Ing..............<br />No Spark......
