Texasmark
- Joined
- Dec 20, 2005
- 14,893
We were over there talking about 2 vs 4 cycle torque on another thread and the question of gear ratio's came up. My natural curiousity got tweaked again so here is the question.
I have a 90 hp 3 cyl Merc. I noticed the same numbers on the older I6 Merc engines.
The gearbox is 2.3:1, as is it's lower hp twin brother (sister) the 75 hp (in the currently designed engine). No other engine (hp) in the Merc lineup has that low a gear ratio; the next lowest is 2:1 and it just goes up from there (numbers get closer to 1:1). And, I noticed that when Merc changed engine designs (from I6 to I3) in the late '80's they carried the 2.3 with the (this) engine.
Since you can prop as you choose and come out with the same result (as I see it), and other engines in that general range are higher gear ratio's, like the 115 hp I6 I had and the newer I3 both are 2:1. Why the 2.3?
Well, you might say that they are designed for high torque, like made for an installation where a big boat is used with a smaller engine; or to pull a pair of heavy weight slaloms at 35 mph on a smaller rig. Ok. I can change props and accomplish that.
Well, I have a 90 on a light boat and have to go to 24P to get my rpm's down to a reasonable level. Well, for the smaller gearbox diameter (4 or 4 1/4 inch don't remember), 24P isn't that easy to find for one thing; you can't buy one in aluminum for example.
If I were running a 115, with it's 2:1 on this rig (same size gearbox) I could find props all over the place.
Just curious.
Mark
Just curious.
Mark
