mostlysnow
- Joined
- May 21, 2007
- 26
Can anyone tell me if there is a difference in gear ratios of 72 evinrude 25 horse? it is in a fiberglass terry boat 16 footer. (Heavy I know)
I had to fix bottom end and before doing so I was able to bring front end up now it wont do it like it used to was wondering if by some chance put wrong ratio in. Now a pontoon can race me to the other end of the lake that is bad...LOL takes me fifteen minutes just to go three miles.
Unfortunately I don't have the old gears to compare teeth on each. Could I need to replace the prop itself?
Also while I am here can anyone tell me where all the screws are that can be adjusted to get more ummp out of the motor I can only find the lean rich (this I have adjusted 1 1/2 turns out) mixture screw and linkage adjustments.
One last question for this thread...my linkage wont put throttle all the way full is there an part of adjusting I might be missing, I have taken the control box apart to make sure linkage cable was ok and looked at where it hooks up to motor everything looks fine ...my handle on motor itself turn throtle full but the controler up front does not. Is there a vacum assist on this kind of motor?
I know this sounds like a lot but any help will be apreciated Thanks to all that reply.
