BigWeakSauce
- Joined
- Apr 4, 2020
- 50
1974 Mercruiser 165, removed outdrive (pre-alpha as some say) for bellows change and separated lower unit for water pump change. Put it all back together, had no crazy trouble getting the upper back into the engine but now that it’s all together the shifting is WAY out of whack. I pretty much can’t get the lever more than an inch into reverse, no trouble going into forward with the lever. When set at full forward gear, lever all the way down, prop spins freely. When pulling the lever back, the prop seems to engage into reverse about halfway before my lever hits neutral position. Seems almost as if my wide open throttle forward position is actual smack in the middle of neutral.
What did I do wrong and how do I fix it? And I just relubed the OD so I’m not thrilled about having to possibly take the lower back off.
