Gearcase Tools
Karl_Childers
Where can I get mercury Gearcase tools? I graduated from a marine technical school in florida and I work as a technician, but I am pretty far removed from the general industry if that makes any sence. I have an old 1988 V6 black max with a bad bearing somewhere and I need some tools to fix this thing. If anyone can help I'd appreciate it. Thanks!!!
Fuzzytbay
Re: Gearcase Tools
I am not sure where, you can buy them, you might try looking on E-bay, as a start.
corm
Re: Gearcase Tools
Hi,
If you can not get the tools from Merc try Sierra.
http://www.teleflexsierra.com/Tools...*****.744318789--store_id.373--view_id.491080
You can probably get the ones you need at a price through where you work or a tax ID number.
Manufacturer Sierra
Part Number 18-9880
The set includes the following items:
18-9813 Shift Handle Tool, replaces O.E.# 91-17302
18-9817 Shift Shaft Bushing Tool, replaces O.E.# 91-31107
18-9818 Oil Seal Driver, replaces O.E.# 91-31108
18-9820 Bearing Removal And Installation Tool Assembly, replaces O.E.#
91-31229A7 (This set includes indented items below)
18-9806 Shift Cable Tool, replaces O.E.# 91-12037
18-9807 Shift Cable Adjustment Tool, replaces O.E.# 91-12427
18-9874 Drive Shaft Preload Tool, replaces O.E.# 91-14311A2
18-9803 Bearing Retainer Wrench, replaces O.E.# 91-17256
18-9809 Bearing Carrier Retainer Tool, replaces O.E.# 91-17257
18-9810 Shift Cable Anchor Adjustment Tool, replaces O.E.# 91-17262A1
18-9811 Bushing Removal Tool, replaces O.E.# 91-17273
18-9812 Bearing And Seal Installation Tool, replaces O.E.# 91-17275A1
18-9805 Puller Washer, replaces O.E.# 12-34961
18-9814 Puller Plate, replaces O.E.# 91-29310
18-9819 Puller Shaft, replaces O.E.# 91-31229
18-9821 Puller Head, replaces O.E.# 91-32325T
18-9848 Driver, replaces O.E.# 91-52393
18-9815 Pilot, replaces O.E.# 91-37324
18-9835 Driver Rod, replaces O.E.# 91-37323
18-9816 Pilot, replaces O.E.# 91-30366T1
18-9828 Puller Head, replaces O.E.# 91-36379
18-9837 Puller Head, replaces O.E.# 91-38628T
18-9808 Bearing Adapter, replaces O.E.# 91-15775T
18-9830 Pilot, replaces O.E.# 91-36571T
18-9836 Pilot, replaces O.E.# 9137350
18-9849 Puller Head, replaces O.E.# 1-52394
18-9832 Puller Head, replaces O.E.# 91-37292
18-9822 Driver Head, replaces O.E.# 91-32336
18-9829 Driver Head, replaces O.E.# 91-36569T
18-9833 Driver Head, replaces O.E.# 91-37311
18-9834 Driver Head, replaces O.E.# 91-37312
18-9823 Bearing Driver, replaces O.E.# 91-33489
18-9824 Needle Bearing Driver, replaces O.E.# 91-33491
18-9825 Bearing Cup Driver, replaces O.E.# 91-33492
18-9826 Bearing Cup Driver, replaces O.E.# 91-33493
18-9827 Bearing Cup Driver, replaces O.E.# 91-34379
18-9831 Bearing Cup Driver, replaces O.E.# 91-36577
18-9838 U-Joint Adapter, replaces O.E.# 91-38756
18-9839 Bearing Cup, replaces O.E.# 91-38918
18-9840 Puller Head, replaces O.E.# 91-38919
18-9841 Drive Shaft Pinion Gear Shimming Tool, replaces O.E.# 91-42840
18-9842 Drive Shaft Bearing Retainer, replaces O.E.# 91-43506
18-9843 Clamp Plate, replaces O.E.# 91-43559
18-9864 Bushing/Bearing/Seal Driver, replaces O.E.# 91-43578A1
18-9844 Tapered Insert Tool, replaces O.E.# 91-43579
18-9845 Seal Driver, replaces O.E.# 91-43591
18-9846 Seal Driver, replaces O.E.# 91-44110
18-9847 Bellows Expander Tool, replaces O.E.# 91-45497A1
18-9850 Backlash Indicator Rod, replaces O.E.# 91-53459
18-9851 Oil Seal Driver, replaces O.E.# 91-55916
18-9852 Bearing Driver, replaces O.E.# 91-55918
18-9853 Pinion Gear Shimming Tool, replaces O.E.# 91-56048
18-9854 Drive Shaft Adapter, replaces O.E.# 91-56775
18-9855 Shimming Tool-Drive Gear, replaces O.E.# 91-60523
18-9856 Shimming Tool-Drive Gear, replaces O.E.# 91-60526
18-9857 Pinion Nut Adapter, replaces O.E.# 91-61067A3
18-9858 Bearing Carrier Retainer Wrench, replaces O.E.# 91-61069
18-9868 Propeller Shaft Adapter, replaces O.E.# 91-61077
18-9859 Puller Head, replaces O.E.# 91-63616
18-9860 Bearing Driver, replaces O.e.# 91-63638
18-9861 Hinge Pin Tool, replaces O.E.# 91-78310
18-9869 Upper Drive Shaft Housing Seal Driver, replaces O.E.# 91-817570
18-9870 Sleeve Installation Tool, replaces O.E.# 91-818162
18-9871 Sleeve Removal Tool, replaces O.E.# 91-818169
18-9872 ater Pump Alignment Pins, replaces O.E.# 91-821571A1
18-9867 Dial Indicator Adapter Kit, replaces O.E.# 91-83155
18-9863 Bearing Carrier Seals & Bearing Cup Driver, replaces O.E.# 91-89865
18-9866 Dial Indicator Holding Tool, replaces O.E.# 91-89897
18-9865 Drive Tool, replaces O.E.# 91-90774
18-9875 Puller Drive Assembly, replaces O.E.# 91-90244A1
18-9800 Compression Tester
18-9801 Multi-Meter/DVA Tester, replaces O.E.# 91-99750
18-9802 Timing Light
18-4442 Alignment Tool
Faztbullet
Re: Gearcase Tools
Get a manual and it will tell you what tools you need to repair your unit. The kit listed above has some items you will need but other 80% fit sterndrives
