I have a 91 Johnson 88spl that i want to replace the impeller on.Followed the step by step in the clymer manual.Not clear on disconnecting the shift rod.I pulled the pin on the shaft,then removed the nut and pulled the"slider", that's attached to the cable,from the stud.Removed the trim tab,screw forward ,and cavity bolt.Didn't pull the prop,not neccessary,right?Removed the 4 gearcase mounting bolts and it dropped maybe 1/8".Wiggled front to back and left to right,but she doesn't budge.Did I miss something?
