guidosarduchi
Thread starter- Joined
- Sep 15, 2010
- 25
I have a 1983 15 hp Johnson short shaft pull start. I bought new screw gaskets for changing the gear oil. I notice when removing the top vent screw there was no gasket on it. I changed the gear oil, and installed a new gasket on the lower fill screw and the upper vent screw. The lower screw looks fine but the top screw sticks out and is not flush (maybe a mm or two). It is in there tight. Is there supposed to be a gasket on the upper vent screw or a reason it was left off? I noticed the top gasket is included in evinrude's gearcase diagram.
Thanks
Thanks
