No more boats
Thread starter- Joined
- May 4, 2023
- 74
2000 ox 66
2 stroke
250 hp
pulled drive too change impeller
top seals , bottom seals
shift seal
gear oil change ( water intrusion )
throttle in N
did not move shifter while changing seal , shifter not easy too move without vice grips
Installed drive
gears grinding ,
forward slight grind
R - louder grind
Into N fine
dropped drive 1/2 dz times ,,
drive was supported by tie down straps so I was able too adjust shifter ever so slightly making sure shifter and hoses lined up
Prior too work no grinding forward or reverse
obviously I am off a spline but cant seem too adjust properly
working solo
this weekend my son will be here , should one of us moving throttle slightly while other installs drive ?
other ideas
thanks
t
2 stroke
250 hp
shift seal
throttle in N
Installed drive
gears grinding ,
R - louder grind
Into N fine
working solo
other ideas
thanks
t
