markhodges78
- Joined
- Aug 4, 2016
- 434
So I pull my 200hp motor off to replace the mounts and trim pump on a 91 wellcraft boat I just purchased I reinstalled the motor on sunday ( using 3m 4200 ) just to find out that the trim wont go alway down so I had to remove motor again to remove the trim assembly but I only removed 1 of the transom mount brackets. well when I removed the bracket the 4200 pulled chunks of gel coat off all way to the glass in both bolt locations... My thoughts on repair is to just build the area up with some resin and sand smooth since it will be hidden by the mounts what are you guys thoughts...
Thanks Mark
Thanks Mark
