Gelcoat over epoxy repairs
Woodonglass
Re: Gelcoat over epoxy repairs
Did you research this or just take the West Systems advertisement as Gospel?:rolleyes:
ondarvr
It has been posted before, and they are the only ones out there saying it's a good idea.
I have personally talked with them about it, when asked directly they say it may not be the best way to do it.
I have tried a few times to get a bond and have never been satisfied with the results, it didn't just fall off, but it didn't stick all that well either.
jigngrub
I found this interesting article in the Epoxy Works magazine by West Systems. Interesting. I have also read posts from other forums about people using gelcoat over epoxy.
http://www.epoxyworks.com/22/pdf/Ew22_Polyester.pdf
Here's another one.
Bateau2 - Builder Forums • View topic - gelcoat over epoxy repair
Not sure what you can do with the information, but there it is. I have not personally tried it myself.
Maybe you should gel coat the epoxied floors on your boat and let us know how it works for you.
RufNutt
Well may I ask what you recommend to cover epoxy on a repair. In a another post i read of yours you told someone to use epoxy putty to fix a void that was found after hitting the hull, but what was he going to do to match his gelcoat if he used epoxy putty which you suggested to use for the repair of the void. Please elaborate as I am going to use epoxy on my repairs. Is there such thing as epoxy gelcoat?
a1964rn
If memory serves me correctly, I suggested that he use epoxy with colored pigment to match up his color.
a1964rn
As I stated previously, " I have not personally tried it myself". I have, however, did some research and found many people that claim they do it with good results.
Yacht Dr.
In a small repair you can use gel over epoxy .. with larger repairs there should be a Tie coat..
Duratec Might ( and I stress Might ) be a viable option for a tie coat.
The thing with trying to poly over epoxy would be an uncured or impropper cure.
I have seen some bad bonds with poly over poxy .. just does not work right IMP.
YD.
a1964rn
OK, here's the deal. I doubt very seriously that West Systems is gonna flat out lie about a test they've done. There are numerous posts on different forums by different people that say they have made repairs using gelcoat over epoxy that has lasted for years. I do understand that some people have attempted it with poor results, where others have succeded. I also know that epoxy is different than polyester and if you do not prep the surface according to the product used, the results will vary. I also realize that if done incorrectly, that it WILL fail. BUT, if done correctly, it appears that gelcoat CAN be applied over epoxy.
I'm not suggestioning that this is the best method. I prefer to use pigmented epoxy for repairs. "Repairs" is the key word. I don't know why anyone would want to apply gelcoat over an entire surfce of epoxy. That would be putting an inferior product over a superior product!
ondarvr
Not lying, nobody said they were, only that some test methods and the real world may not yield the same results.
We make epoxy compatible gel coats, but they are designed for in mold use, not post application because there are too many variables involved to say it will work reliably. I won’t recommend something that has a good chance of not holding up long term.
Inferior depends on the criteria its being evaluated with. For bond strength yes, epoxy beats polyester by a big margin. If you are looking at UV degradation then polyester will beat epoxy by a similar or even larger margin.
jbcurt00
It seems like argument for arguments sake....
a1964rn
Yeah, you're right about the UV degredation.
Yacht Dr.
I have personally spoken to WS Tech Support as well .. I get the same thing. "It can be done but with methodical prep." You cant just use WS and expect a good gel repair Over it without some complications. Your application of Gel could suggest a problem dependent on what solvent you use in the mix. ( styrene, Acetone, Mekp, Cobalt .. many others ) .. could these be a problem with bonding of the gel ? Its NOT a blank page saying the WS system is not compatible with Pure poly products. .. but you will have to Add Solvents. Now .. are they going to suggest if you use XY or z solvent that it would not affect there product bonding issues with your gelcoat ? I doubt they have the RnD developtment team working on these issues.
YD.
Im sure it was not WS epoxy that was used .. but there has been a complete Failure in the curing of not only poly over epoxy but VE resin over epoxy in some of the repairs that I have tried ( and failed ). It just Did NOT cure !
I dont know why .. Im not a chemist .. but I think it had something to do with the Solvents in the Poly. I will Never use Poly over Poxy for a repair and/or final coat again.
Your using Pigmented West System Epoxy for repairs ? Why ? .. Your not priming ? .. just going right from layups or thickened putty to Gel coat for a top finish ?
It Would Fail .. has nothing to do with inferior product or superior product .. its just NOT THAT COMPATIBLE for a larger surface.
And 'May not' is the key here ... there are not a lot of peeps out there that want to spend/or afford West System Epoxy ( I will add that IMO WS is one of the BEST Epoxy Products out there for Epoxies ) Lets not mix up other systems together with WS.
Just my $4.38 worth ...
YD.
a1964rn
002-550 Fiberglass Boat Repair & Maintenance
Published by
Gougeon Brothers Inc.
PO Box 908
Bay City, MI 48707
866-937-8797
Epoxy by the Leading Epoxy Manufacturer | WEST SYSTEM Epoxy
15th Edition ? 4/11
2.2.1 Gelcoat finishes
In answer to questions concerning compatibility and techniques for applying polyester gelcoats
over repairs made withWEST SYSTEM Epoxy, we can say epoxy provides an excellent base for
polyester gelcoats. The following procedure will assure good adhesion and a well matched repair
color.
a1964rn
Classic Whaler: Boston Whaler: Whaler-Radio
About halfway down the page is an interview with Jim Watson of West System recorded April 4, 2000.
Click on "Classic Whaler Radio: Part 1 with Jim Watson of West System"
He tells you how to prep epoxy for gelcoat.
Yacht Dr.
Yea .. um .. well .. he didnt really describe Too much about how they did their whaler project because they sprayed it with ALW GRIP ...
Also the interview seemed scripted towards the "reply" of the interviewer more than the "answers" of the guest.
That was an interview almost 13 years ago as well.
Like we suggested here in the thread .. You CAN do poly over some epoxies ( Not all of them ) with proper prep.
If you feel so inclined from what you read or hear about it being not so bad of an issue then please continue to so at your own risk. I dont think your gonna get any thumbs up no problem posts here.
YD.
