Re: gelcoat sanding
R U sure that's poly. Metal flake boats are made by putting down a base color of gelcoat and then putting metal flake in the Clear Gelcoat top coat. The pics are typical for a Metal flake Boat that has been left out in the elements. There is not a lot that can be done. It's been discussed a BUNCH here on the forum and the general consensus is to sand id down smooth and Paint over it. You're just NOT gunna be able to get the original shine back when it's that far gone. I seriously doubt that the PO put Poly on the boat. It's just the Clear Gelcoat that you're seeing and dealing with. I sent you a PM
