Gen 2 drive oil reservoir audible alarm wiring
fairshopperguy27
Does anyone know if the DDIS wiring harness has wiring for the two wires on a Gen 2 drive oil reservoir? Any help would be appreciated!
fairshopperguy27
Ok, thanks I'll look for that tan/blue wire. There are two black wires coming from the bottom of the drive oil reservoir tank, would I just plug one wire into the tan/blue wire then splice the other into the ground wire in the harness?
The bottle is a switch, plug one into the tan/blue and there should be another black wire with the same type connector. The black is ground and makes no difference which one is plugged where
Fun Times
Typically the tan/blue wire harness has a connector in the general location of the oil reservoir mounting area along with a wire plug connection connected to a black wire for the grounding circuit....No splicing into a black ground wire should be needed unless you can't find a unused black wire connector that would just plug into the reservoir.
fairshopperguy27
This is an 89' 3.0 with DDIS so it doesn't have the two wires in the location of where the reservoir mounts. I think I will have to splice both the ground and the tan/blue wires into the harness. Hopefully they're not to far back on the harness.
As in FT's link to the pdf file. Add a wire from one of the two sensors (oil pressure or temp) and run it to the bottle, then ground the other side.
fairshopperguy27
Ok cool. Should I ground it to the block or splice it into a ground wire in the harness?
Fun Times
Ah that makes sense as I was thinking 1991+ for the wire connectors are typically in place. 1989 didn't utilize the gear lube warning horn so you would have to splice in like AllDodge describes above. Sorry for any possible confusion.
Just so you are aware, your warning horn system if original to Mercruiser should have a 7 - 14 second delay before sounding the horn at key up. See page 2 for some info about it, http://www.remanual.com/file-manuals/9iJ/mercruiser-horn-warning-systems-ari-inc.html
