supercobra
- Joined
- Jul 11, 2026
- 26
Bought this Baja force 250 with mercruiser 454 in it and replaced all gaskets .I also bought a parts engine to get parts and bolts from.Now after installing the original balancer it starts whining like a bearing is going out on a accessory pump.I then tried the parts motor balancer and it does the same thing.I took it off finally and it doesn't make no noise at all.WTF!! IS going on?It didn't do it before,but I did replace the timing chain cover seal for the balancer.Can that be it?Both balancer measure the same or real close.I even pulled it out a few thousands or millimeters.There is a line wore on the shaft of the balancer on the outside where the seal of timing chain cover is.Could this be it?The sound is unbearable.
