GEN IV & Gen V oil pressure compatability issues
OldNBold51
After successfully mating my Gen V 7.4 heads and intake to a Gen IV replacement block due to poor winterizing skills leading to a cracked block........I have an issue with the oil pressure sending units.
The Gen V had 2 ports for oil pressure sending units, 1 for the sending unit to gauge and another for sending to audio warning buzzer. The Gen IV only has 1 port near oil pump. What is the best and easiest way to get both the gauge and the audio working properly?
havasuboatman
Ensign
Re: GEN IV & Gen V oil pressure compatability issues
Use a piece of tubing from the block to a "T" fitting. install one sensor into each of the remaining openings. Voila!
