Hello all, 470 alpha one gen one and it looks like the bearing came out of the housing. Everything ran perfect, no issues whatsoever going out to the islands. But when I started it up to head back to shore I heard a horrible clanking down there. I take a look and the yoke is jumping around in the housing (not at the engine). So the bearing needs replaced. I noticed on a few threads through the years of talk about a gimble bearing that is sealed and does not need to be greased. Is this bearing available for the gen one? And if so where can I find them.
Also, I plan on changing the props again. If I go from aluminum to SS do I need to change size or pitch? Or would it use the same size props.
