Gen1 oem impeller kit (frustrated)
a70eliminator
Dont need the entire housing, just the impeller & gaskets, I lost the little seal for the gear lube transfer hole & hope it comes in the impeller kit, if need be I'll replace entire housing.
Anyhow.....can anyone help be posting a part number or link to gen1 kit all Im seeing are gen2 uggh.thanks
Scott06
The kits are in the parts breakdown couple different options with and without housings and bases.
ddrieck
Which seal are you looking for, is it shown in the picture?
Quicksilver 47-89984Q-5​
The pump kit should have the quad ring in it, if not, it is available as a relatively inexpensive separate part:
25-48452 QUAD RING​
crazy charlie
That oring can be reused if not damaged.It will work fine as long as your upper and lower are mated together tightly.Charlie
Scott06
Not sure what to call it..its a quad ring about the diameter of a pencil, it sits in the oil tranfer hole between upper and lower.
its the orange thing just below the impeller in the pump kit shown above.
I have usually found that going OEM for impellers and components is best
