General carb question....
stevetedder
When the throttle control lever is all the way forward WOT position, shoulnt the butterflies on the carbs be wide open? mine are barely open, should I adjust this?
kbait
Re: General carb question....
They should be and yes you should adjust. Search 'link/sync' and you'll find a ton of info.
stevetedder
Awesome, I thought that was strange but I am just basing that from a carb on a car. Thanks for the reply.
F_R
Don't just adjust it.....Find out WHY it isn't opening all the way and fix the CAUSE. Otherwise, you could be just adding a second problem, if you adjust the wrong thing.
BTW, it might not be a motor fault at all, could be the remote control.
bob johnson
yeah for sure , see if the linkage on the motor itself allows the butterflys to go wide open!!!
hopefully it is a cable issue and you are just bottoming out on the controls stroke limit.
good luck
bob
