General Check ,Oil Ect.....
BRAD4FIN
Hello's,<br /><br />I'll try to be brief..Is this all correct ?<br /><br />This is what I think I have with some help from AMD RULES.<br /><br />1985 <br />Brown Band <br />Mercury 60 <br />ELPTO (what does this mean)<br />Serial no. 4 9431101<br />3 cylinder<br />Double arm power trim n tilt (oil type?)<br />Electric start <br />Oil ratio 50:1 or 40:1 (oil type?)<br />Plugs (best type?)<br />Also can i use normal carb cleaner?<br /><br />Any other Tips/Sites About this engine would be luvly.<br /><br />CHEERS BRAD...........
AMD Rules
Re: General Check ,Oil Ect.....
E Electric<br />L Long Shaft (20")<br />PT Power Trim<br />O Oil Injection<br /><br />Does your motor have oil injection, rather than having to pre-mix with the gas? Mixture should be 50:1, of Mercury (Quicksilver) TC-W3 or equivalent. Oil brand is a personal choice, but it must meet TC-W3 specifications.<br /><br />Oil type for PT&T is recommended to use Mercury power trim fluid, but ATF is suitable as well. Whatever you use it is best not to mix various fluids. Flush and fill system when changing from one to another.<br /><br />When cleaning carbs off the motor, any carb cleaner will work. Never run your motor using quick start or carb cleaner. The cylinders/bearings/seals require the lubrication from the fuel mixture at all times.<br /><br />Check with yout dealer for proper spark plug specs. May be a couple of options depending on how you want to use your motor (trolling, fishing, skiing, etc.) to avoid fouling.
BRAD4FIN
Thankyou for the help and superfast replies. <br />I like the wake shot, nice..<br />Cheers.<br />(I have to pre mix)
