Re: general question for everbody
A 17.5ft boat should be rated for a 150, and thats what I would install. If its a bass boat the 115 & 140 will strain on this type hull when its fully loaded with 2 people,18 gallons of fuel,gear and 15 gallons of water in livewell. My 250 is slow out of the hole when its fully loaded (50 gal of fuel and 35 gallon in livewell & 28 pitch prop). You will also be able to run faster and at less throttle setting as the smaller engines would have to run more throttle to run same speed due to gear ratios and prop diameter/pitch.
