Generator Spinning like a electric motor with engine off??
tritanusa
I have a 1960 Evinrude Lark 40hp and it has a side mounted generator. Problem is the generator spins like a electric motor at a pretty good fast speed like a power drill speed and runs the battery down.. The belt is removed. There are three wires, 2 of which are green, one was connected to the generator, 1 green one is not connected and has a spade connector on the end that goes around to a silver thing on the back of the motor.. Another I believe purple wire goes to the other post on the generator.
Thanks in advance.
boobie
Re: Generator Spinning like a electric motor with engine off??
Sounds like some screwed up wiring or a bad cut out relay in the voltage regulator.
F_R
Honorary Supreme Mariner
Definitly screwed up wiring. That may in turn have destroyed the regulator. The generator wires are blue (field) and yellow (armature). There are no purple wires.
