Re: get lower unit off
Have you removed the fourth screw? If so, you should find that you can force the unit off of the stubs of the broken bolts. <br /><br />Most of what caused the bolts to break was within the unthreaded opening, so depending on what is left after removing the lower unit, the removal may be relatively easy.
