Well I bought an old 1442 Ouachita V-bottom from a local scrapyard. Got the boat, a homemade trailer, and a 64 Evinrude Fisherman 5.5 for 250.00. Got the titles for all three too. The trailer is solid but needs a little work, and the 'Rude is in great mechanical shape and runs good.
Anyway I got hosed on the boat. Though I looked it over pretty good but after I got it home I noticed it had a substantial patch on the bottom. Looks like it's been run onto a stump or something and had a pretty big tear in the bottom under the rear bench. After some consideration and research, I decided to go ahead and try to patch it. The PO patched it once before (half-assed at that) and it worked for them. I pulled the rear bench and got to work.
I used .025 aluminum sheet for patches, one inside and one outside, with 5200 between them and around the edges. I used 1/2" 1/4-20 machine screws to hold everything together. It's not real pretty but I am confident that it will work fine for this boat (using on rivers, and the small lakes around here on calm days.)
The weather here has been less than ideal. It's been a roller-coaster. When I put the big patch on it was a really nice day (Monday) around 52 degrees. The past two have been 15-20 for the high, and it's supposed to be around 50 this weekend. How much will the cold affect the curing process? It has been 48 hours now and it hasn't even skinned over, just gotten a little stickier. Will it cure at all?
I am in no hurry to get it in the water. However I don't wanna wait until the end of February. Is there anything I can do to help it out? I don't have anywhere warm to put it... Would take a cord of firewood to keep the garage heated for a week. Ain't gonna happen.
Thanks.
Thanks.
