dlogvine
Thread starter- Joined
- May 4, 2015
- 839
Im not sure if this is a correct forum topic but could not find the better match. However, here is my problem. I just got a nice 2000 Larsen 176SEI hull with everything in perfect condition minus (a very big one too) the engine, transom plate, gimbal and outdrive. Original engine was Mercruiser 4.3 v6 vortec with 1.81 Alpha One gen 2 outdrive. At first I wanted to swap the whole setup from my older 1993 Larsen SEI200. It has a v8 305 mercruiser. But I dont want to take apart a good running boat with just rebuilt engine, so Im thinking about getting a completely new (used) drivetrain for the new boat. I have a couple remanufactured, cleaned and one rebored .20 over, but not assembled chevy v6 blocks. One is 1993 prevortec with the balanced shaft, the other is 2002 vortec engine. Both have heads and both are automotive. So I thought about buying a used (maybe seized or cracked) block of similar type and then rebuilding it using marine parts from the bad block with my SB's. I found a complete setup 1994 Mercruiser (kind of old and seized) with the exhaust manifolds, flywheel and coupler, all ignition parts and accessories (starter, steering pump, alternator), not tested. The seller wants $750 for it. So Im kinda in between. First, I wanted to put a vortec engine with vortec heads (I have a perfect pair of them), so going back to the pre vorrtec engine is a step back. Second, im not sure if the price for the seized engine is not too high. And lastly, 'd still need to get a transome plate, gimbal and the outdrive. Should I wait till the end of the season and buy some trashed boat with the complete setup and then take it apart or this is a good price for the block and just buy it and look for the other parts later?
Thank you, any advice is good. Also, is there any place I could look for the complete engine/outdrive set at a reasonable price?
