getting impeller to fit in housing
aanda6
Hi, just got my new water pump kit arrived from the USA, still waiting on manual.Question is how do I get the impeller to fit in the housing? looks to big, I'm sure it's simple but until the manual comes I can't work it out.
bubbakat
Re: getting impeller to fit in housing
Just Install the impeller on the shaft and put a little lube of some kind in the cup. Hold the cup down on the impeller and with a little downard force while roating the shaft in a clock wise motion it should go right in.<br /><br /> Impeller replacement<br /><br /> view after it is placed in the cup
aanda6
Thanks Bubbakat, i'm sure the manual would tell me I'm just impatient. I love the assistance and the information available on this forum. I feel that I learn something new everyday
Chinewalker
Liquid dish soap works well as a lube and will easily rinse out when the motor is running without harming the rubber pieces...<br /><br />- Scott
Cricket Too
I usually just lube up the impeller and the cup and twist the impeller into the cup so the vains are in the right direction and then install the whole assembly onto the shaft and down onto the baseplate.
aanda6
Thanks for the replies. i will have a go on Saturday, hopefully my manual arrives by then too.
