Re: getting on plane with my 350V Merc XR2 150
I'm looking at a '87 Ranger catalog and the specs on the 350V are 17'10", 82" beam, 150 max hp, 1050 lbs approx boat weight. Don't suppose there was a lot of changes in those 5 years. There is a picture of it with a Johnny 150 on it, side view and on calm water, the only thing that is in the water is about 2' of the pad. That suggests 60 mph sort of thing which I believe.
On soaking foam, Forrest was real good about foaming everything but sealed it and in the keel area, from fore to aft was a rectangular tunnel for water to drain into, flow to the back, and all be removed at the transom by the bilge pump or drain plug.
Just how much soaking do you think this boat got?
You already told me what I need to know. Assuming your XRII has the high speed 4 1/4" gearbox, you are running a 1.78:1 ratio. With a 19P (20 for calculations assuming yours is SS and is cupped) and 12% slip (good estimate for that hull, my opinion) @6000 you should be doing 56 mph. So if you are currently running in that area at WOT, your engine couldn't be in too bad a shape......you didn't specify speed.
To drop WOT rpm's and use the 23P Tempest (24) as suggested, and keeping the 12% slip the boat would be up to 63 mph (at 5600 which the book says is the recommended max WOT rpm) but your hole would be worse (maybe....see comments about ported prop).
Sounds like you have extra weight in the transom.
What are the dolphins you took off? Something to help get up and going like trim tabs or a whales tale?
Book says the boat has a pair of 14 gallon tanks which are probably back there too, so if full, that's a couple hundred pounds, plus 50ish for the 4th battery and who knows what for your deck extension. area and you'd expect the hole to be slower.
But if you use a ported prop, you can recover the hole; and proper trim angle is a must. I had a 19P ported Merc SS prop on an '89 115 hp Merc (2:1 gearbox) on a Ranger 680C (foot shorter and 200# lighter than yours) which was also padded which worked real well for a good hole.
I can't tell if the Tempest is ported, but you can contact Merc/accessories/props and ask. Also insure that you know what your lower unit diameter is (4 1/4 or 4 3/4....which is a 1.87:1 ratio). I wouldn't use one on that boat that wasn't.
My 2c,
HTH
Mark
