getting ready for winter
rockyman
was wandering if anyone has ever used a heating blanket to keep their inboard-outboards form freezing . i want to keep using mine a couple more months because i have catfishing tripps booked . i am in the central va area and the temp here does not get that cold . maybe high 20s and low 30s at night.all inputs welcome. thanks.
Re: getting ready for winter
We don?t have near the cold weather you folks in VA have and if it gets cold enough to freeze an engine, we prefer a warm fire and two fingers of a good pusser's rum. However, we have seen a couple of ways to keep the engine safe. (The assumption is yours is not a closed cooling system, in which one could simply add antifreeze.) One method we have seen involves installing an inline thermo-heater in the cooling systems that uses a simple 110v power supply. Another more basic approach is to place a light in the engine well, usually a 100w, to generate heat. The same fellow that uses the light in the engine also places a lamp with a reflective shade placed close to the outdrive to keep it warm. As the saying goes ? ?Necessity is the mother of invention?!!
Ayuh,.... A Cold Snap,+ Power Outage will guarantee you have a Cracked Block...
Draining is the Only way to be absolutely Sure there'll be No damage....
Grant Brown
The night I bought my boat with 4.3 merc I/O was freezing and snowing heavily. I had just run the motor and had to drain it. I didn't trust that a bulb would keep it from freezing. I pulled manifold the hoses, water pump hose, power steering cooler and block drains in about half an hour in the dark with the snow whipping around. I can now do it in less than 10 minutes in good conditions. I plan to use my boat this winter fishing feeder spring salmon and will have to drain it each time. I would say drain it completely and you won't have to worry.
Grant
rockyman
okay, thanks guys for the input.
