bruceb58
- Joined
- Mar 5, 2006
- 30,797
Re: GFCI outlets question
To add to this explanation, the neutral will only carry the difference between the load on the two legs. If a load on each leg is equal, the neutral will not be carrying any current at all. If only one leg has a load, the neutral will carry the whole current of that load.There is no reason to run separate neutrals on a MWBC because theoretically it will not carry the current of both receptacles at the same time....AC,alternating current. Only one receptacle at a time (8.3 milliseconds) can be on.
