elkhunter338
Thread starter- Joined
- Jun 27, 2009
- 818
Re: ghr gimble repair kit
silicone was not used to seal the water out, it was just used on the inside to prevent any more corrosion to the alum. if more water got into the bellows area.
I can't see why silicone will react with alum. They use it in automotive uses with alum.
I can see salt water getting under the silicone between the alum. then causing more corrosion, but this will only happen if the silicone does not stick to the alum.
I plan to pull the drive after I use the boat for a week to see if any water is in the bellows. I sealed the bellows with bellows adhisive and only added th silicone to the inside, which I can remove. What would you recomond I put on the alum to prevent more corrosion if water leaks into the bellows again in the future. What ever I use needs to not react with the bellows.
Thanks,
Thanks,
