bluemarshboater
Thread starter- Joined
- Jul 6, 2009
- 118
Sorry, I should know better than to post without the correct info.
The unit is a 5.0 mercruiser with an alpha 1 gen II drive.
When installing the gimbal bearing, how is the alignment tool used...... must you have the alignment tool in the entire time your installing the bearing? I'm sure that is best procedure right?
When the bearing is installed all the way till it bottoms out, that is not aligned? So the bearing in essence then, to be correctly aligned, maybe in there a bit less than straight?
Thanks
Dave
Thanks
Dave
