Gimbal bearing install
dozerII
I am running a 1986 4.3 lx 205 with an Alpha outdrive. I have a gimbal bearing from a Quick Silver transom kit. There is a yellow dot on one side, does this go inboard or outboard when installed in the housing.
Thanks in advance.
Don S
Re: Gimbal bearing install
You should see the dot in the upper left of the bearing after installing it. Directly opposite the grease zirk hole.
dozerII
Thanks a bunch Don
