Re: Gimbal bearing installation backwards
Although I do believe that it is better to replace the unit as a whole, I do not believe the statement in the service bulletin that Ziggy posted, (thanks by the way
), where it says the number one reason not to simply replace the bearing is because...
The bearing is selectively fitted to the cartridge during manufacturing and must remain together as a matched set.
I genuienly do not believe they custom fit each bearing and cartridge together when they make them. (I can see some line assembly worker with a set of calipers making sure this bearing is the right fit for that cartridge.
Reason number two is probably the real reason:
Secondly, bearing may be damaged from lack of lubrication, if bearing is installed backwards.
Ah! That I can understand! Customers - or mechanics - replacing the bearing and not understanding that the grease hole needs to be on the same side as the slot in the cartridge - no grease gets to the bearing... the rest is history.
Just remember when you do replace the bearing assembly that there are still some things that need to line up. The tolerance ring opening needs to be in line with the grease hole.
