Gimbal bearing.
ericcarr
I figure there’s no need in replacing it if it’s not dry rotted or cracked or anything. There’s nothing wrong with that I just thought that since I had my drive and motor out that I will change it but oh well
dubs283
Hmmm ok….looks like I’ll just leave the dang thing in then.
You can remove the fitting without the special tool, it's just a socket that has four tabs on the O.D. to engage the splined portion of the insert. By the looks of the corrosion and buildup of crud even if you had the special tool most likely you'd be replacing the insert. Kinda funny how you got the bell housing side off but now you feel this is too much?
As I stated earlier, Bravo water passage hoses rarely fail, best to just leave it alone if all is good, ymmv
ericcarr
Hmmmm ok, I just thought about something. When I first bought this boat it had the bravo 1 drive on it, doesn’t the 1have an impeller located in the drive itself? The reason I’m asking is because I’m pretty sure it also had the impeller located on the starboard lower side of the engine .
Brav
Bravo does not have a impeller in the drive, only one on starboard side.
ericcarr
Hmmm ok that’s what I thought. Has anyone ever hooked up a hose directly to the pump instead of trying to use the muffs?
Suse, with
Sure with drive removed, just connect hose to input bell housing connection.
Or remove belt to pump and connect hose to input connection at thermostat housing
ericcarr
Suse, with
I think that’s what I’m gonna try to do when I drop the motir in her to get her up & running…I hate them damn muffs….
ericcarr
Another question, pertaining to the bellows, has anybody on here ever ordered and installed the Bellows that aren’t so darn expensive? I mean I know the quicksilver Bellows kids are over $400, when you can get bellows kits on Amazon or eBay for right around 60 or 70
Ayuh,..... It's a false economy,....
I've run Sierra, 'n won't again,.....
Rick Stephens
Eric,
They have more issues in installation and staying attached than they save. At least with the Quicksilver stuff it last for a lot of years - especially if you remove your drive each winter and let the bellows relax.
nola mike
I'm in the minority having run Sierra rubber bits without issue. Seems something else always breaks first, and I'm replacing the rubber before it wears out anyways. Last bellows are 4 years in and look brand new
Lou C
On the Cobra I’ve used the OE bellows & have gotten 10+ years out of them with the drive stored down. That’s about when you start to see small cracks beginning to form in the folds. That’s a sign the rubber is getting stiff and is due for replacement.
ericcarr
Are they the sierra kit?
JASinIL2006
Too many reports of problems with intallation and longevity of non-OEM bellows for me to even consider them. Changing the bellows is a major pain in the backside and I don't want to do it any more than absolutely necessary. If it costs me a couple hundred extra bucks, it's more than worth it. (Added to that is the catastrophic downside of having your bellows fail while on the water. I'll pass on that, thank you.)
Lou C
The price difference isn't even that much. We have this boat almost 20 years, bellows has been changed 2x once in 2005 and once in 2016. The OEM ones are only like $60 for the Cobra. I use OEM whenever I can for the bellows, impellers, fuel filters, etc. The price difference is really insignificant all things considered. The reality is that aftermarket is sometimes easier to find locally.
