Gimbal grease
77searay197
I was wandering what grease y’all recommend using for the gimbal? I wanna grease it before I install my motor so I can hand turn the bearing and get the old grease out. I have a Yamaha sterndrive. Anyone ever used this stuff? Seen it at Walmart Says it’s for high speed and has water resistance
Ayuh,..... You can use whatever grease ya wanta use,....
I use plain ole chassis grease from Napa, as that's what's always in my grease gun,....
'n I grease the gimbel bearin' when runnin' the motor on the muffs,.....
'bout 10 pumps is plenty, probably to much, as I've always found the purged grease in the bellows when I pull the drive,....
77searay197
Cool, I seen some of this too I just wasn’t sure if I had to use a specific type or not
