NWVintage
Thread starter- Joined
- Aug 8, 2011
- 65
Long story short, I'm replacing my gimbal housing, gimbal ring and bell housing on my pre-alpha outdrive. I got the three parts as a unit. I took every measurement that I thought would be important before I undertook the project and everything looked and is good except that the little collar on the back of the gimbal housing through which the drive shaft passes is thicker than my other one...? It has the same internal diameter but the walls are about 1/16" thicker for an external diameter that's 1/8" larger than the hole in my transom plate.
Does anyone have any pearls of wisdom regarding what to do with this? Literally everything else matches up and fits. Do I just take the grinder to it? Is there another transom plate out there? I thought that the transom plate was the same for all mercruiser roughly 1976-1982...? I have transom plate 65550.
The SN on the gimbal housing is 5969865 which falls into the SN range for a number of engines 1979-1982 (Including '80-'82 470's). My original is a 1978 470.
I also just went through a bunch of parts schematics and literally every drive setup for which that SN is within the range calls for transom plate 65550. So it should fit. Just doesn't...
