Gimbal Ring R/R--Oh what fun!
L8-Again
I took the plunge this weekend and I am going to replace my gimbal ring. I have a 1979 Fiber-Cell Cordoba with a Mercruiser 350 Chev. The label on the engine and old out drive say "Mercuriser 260." Two years ago I replaced the sterndrive with a complete SEI 106 unit. Up until a week ago I thought I had an Alpha I Gen I, but now I know I have an MC-I or pre-Alpha. The serial number on my gimbal is 77124 S.
I noticed that I had a lot of steering play and found the the gimbal ring had 'wollered' out. A previous owner had drilled and tapped a type of lock bolt into the gimbal to hold the swivel shaft tight. My gimbal is the spline/spline style and since the part that passes into the gimbal is split by design, they had the stop bolt positioned to put pressure in the split. I thought it was normal, this being my first boat and all, but was frustrated that every time I took the boat out, the bolt would loosen and the outdrive would get all floppy again. I used red lock tight several times with no success.
So, with many hours invested into reading on this site I have determined that there are some issues with the spline/spline design and that it would be in my best interest (health and safety!) to replace it with an updated square/spline gimbal before anything catastrophic occurs.
I can buy a new gimbal for $600.00 or buy used for $200.00. I know you never know what you are going to get when you buy used. My wife has budgeted $1500.00 for repairs. The exhaust manifolds look like they are 30 years old, too, so I want to replace them and upgrade to the center discharge as well.
I have dreamed of ripping out the interior and doing a complete restore, many threads on this site have inspired me to do so, but the interior is fine, the boat is very solid (and heavy) and I should get the mechanical things done first.
The exhaust is showing signs of age and I seriously worry that it will fail, on the water of course, and I will end up with swimming pistons. I did find an exhaust kit for from Moore Performance for $625 with free shipping and almost bought it right then. But as I looked at Seinna kits, and others, I found that they cost more because you get more: like hoses and brackets and thermostat housings etc.
This is a 30 year old boat and I was extremely surprised at the condition of the transom and bell housing. I suspect that these parts may have been replaced at some time during it's life because there is virtually no corrosion on them. The paint is still shiny in many places.
The engine is strong, starts right up when hot or cold and does not burn oil.
Here is my list of things to do:
spark plugs, wires, rotor, cap, points
gimbal ring
lower shift cable
repair my leaking trim reverse lock valve (hopefully)
exhaust manifolds/risers
install continuity kit on outdrive
gimbal bearing (there was some water in the bellow when I removed the drive)
So does $1500.00 sound about right? Oh, and I will be doing my own work.
Sound impossible/improbable??
I am considering the Merc kit for the gimbal 88302A-1. I was thinking that the Alpha I Gen I gimbal, 94993A-7, is the same gimbal in the upgrade kit I may get, but I have no way of knowing if this is true. If they are the same part, then I can get a used 94993A-7 as long as is comes with a square/spline swivel or pick one up somewhere. The frustrating part is that both of those part numbers sell for about the same price, yet you get several more parts with the upgrade kit. It is truly a better deal to get the upgrade kit in my situation if I went new. But I want a new exhaust too! And I don't think I can cut enough corners to make this work going new all around.
I have also read that the bell housing may have to be trimmed when changing the gimbal, but I can't remember where I saw that. They even had a plastic guide to get the angle correct when grinding material away. Anyone hear of this?
Any sources, help, teasing, suggestions are welcome!
Oh there is the possibility that I can send my old gimbal to a machinist and have him do some magic on it. But I have been frightened by information that I read about the spline/spline being junk and dangerous. Any thoughts on this? Is the spline/spline really bad? Hey, just had another thougt! I wonder if a machinist could take my spline spline and make it a square/spline and I would only have to get the swivel shaft!
Anyone have any guidance for me?
Rich
Re: Gimbal Ring R/R--Oh what fun!
Ayuh,... I can buy Good used freshwater, not corroded, tight, Alpha 1 transom assembleys all day long for $200./ $250....
Updated trim rams,...
Updated sq. swivel pins,...
Updated everything...
I see it as the Only option, myself.....
L8-Again
Bond-o
SOLD!
Send me a PM with your address and I will mail you $300.00 to send me one! That is, of course, if it's okay!
Don S
Bond-o
SOLD!
Read his post, he said he CAN buy them for that price, not that he has one.
Besides, posting a reply like you did is completely against the forum rules. That is where you should use the PM yourself, not the forums.
Ayuh,... I didn't say I'm sellin' 1,...
But, it appears I'm about a hundred bucks low...
I'd still go with something like This,..
L8-Again
Didn't intend to break rules. Won't happen again.
Thanks for the input Bond-o, I will consider a used assembly. Money does go farther buying used. From what I have read on this site, I have nothing to lose if I trust your judgement. Maybe that's why I was so eager to respond back the way I did earlier. I don't trust used parts too much, especially if I can't get a hand on them. But coming from a trusted source--IMO this site has trustful people using it--I was all to ready to 'assume' there was an invitation, and, by doing so, chew on my foot! My apologies.
stonyloam
Try e-bay for "alpha 1 transom assembly". Good luck
L8-Again
So, I have been checking in to purchasing a used Alpha I Gen I to upgrade. The transom I have is stamped with 65532-S. From what I can tell the Alpha I Gen I has some differences from MC-1--obviously they wouldn't re-name it if it was the same!
I want to make sure I am understanding correctly, a little slow sometimes. . .
If I get an Alpha I Gen I transom assembly I would need to change rear motor mounts, Y-pipe, engine coupler, flywheel bell housing and possibly steering? I hope I am wrong with this!
The other possibility I have thought of is use the bell housing and gimbal ring off the Alpha I Gen I and mount to my existing transom (65532-S) so I wouldn't have to change the Y-pipe, etc.
(Chev 350--Mercruiser 260 on valve covers--with ser# 5060620 on right rear side of engine)
Ayuh,... I believe,....
If you use an Alpha 1 Outer transom assembley,...
You could use the Mod.1 Inner plate for the motor mount spacing, 'n any steering issues...
But,...
I believe, you'll probably need a different Y-pipe...
There's a few different possibilites with the Y-pipes....
And,...
I have No Clue as to whether you can mix, 'n match the gimbeled housing, or gimbel rings, 'n pins....
Fishermark
Actually I don't believe you can. I have made quite a few similar swaps and there is always a "gotcha" or two. The inner and outer will more than likely need to be the same. At least I know the 70's vintage boat I currently have (inline engine) has a different pattern and the old inner transom did not match up with the alpha transom assembly.
L8-Again
The Y-pipe issue may be difficult to solve with removing it and comparing with the Alpha I Gen I outter transom housing. I have been looking on-line and haven't had much success with pictures and descriptions. I have found two different ones, 3" and 4" for Alphas Gen I, II; but there is also some other choices I'm not sure about for pre-Alpha. . .and I have yet to remove my Y-pipe and get the numbers off of it. I will keep digging and see if I can come up with something, or someone who has done this.
I have found some pictures and part numbers for the bell housing and gimbal ring that have been vey helpful. Bell housing 42815A6 is used as a replacement on 76-90 Pre-Alpha and Alpha. Gimbal ring 88302A1 is used as a replacement on 76-90 Pre-Alpha and Alpha--this is the kit to upgrade the Pre-Alpha to Alpha. Gimbal 94993A7 is the 84-90 gimbal. In the description of the upgrade gimbal it talks about the square/spline and square/square for the swivel shaft. Only the square/spline can be used on the 76-83 because the outter transom housing has a different sized bearing, but it appears that the 94993A7 can be used as a direct replacement of 77124-S as long as you use the correct swivel shaft for the outter transom housing. The hinge pin 77123 falls into the 76-90 range also. Mine is threaded and does not use the nail. (All of the date ranges I used are approximate windows--serial numbers of course need to be used to verify application)
Please let me know if I have gotten any bad info in the above paragraph ^^
The other thing I am trying to figure out is if I need a different trim pump if I get the Alpha style of rams. I rebuilt my rams and trim pump last year (basically new seals, o-rings, a good cleaning and paint) and it has been working great other than a leak at the reverse lock valve. I have found the seals to fix that.
Getting closer to having a solid plan before blindly ordering parts!
L8-Again
Progress is happening. I was able to acquire some used parts and am just about ready for re-assembly. I have not been able to find any significant difference between the 1989 Alpha I gimbal ring and bell housing I purchased as compared to the pre-Alpha parts I am removing, whew! I also found a square/spline shaft to use with the newer gimbal. For now the old transom is in great shape for being 30+ years old. I will post some more pictures as the work progresses.
I did chose to drill the 1 1/8" holes in the old transom to remove the gimbal. Some day I will re-power and use the newer Alpha I transom that came with the used parts I got.
I ground, sanded, washed, and washed, and washed (soap and water, then acetone X's 2) to make sure the paint would last more than a day! I used vinegar and a scotch scrub pad to etch the bare aluminum and then primed with zinc chromate. I used Rustoleum professional glossy black in a rattle can. All thanks to info I found on this site.
The bottom picture shows the 'wallered' out splines on my old gimbal. Less than half of the splines are left! Sure glad nothin' broke free while I was cruisin' the lake last year!
jearl
interesting project and going through the same challenges right now. I also going from MR to alpha drive. I purchased used outer transom assbly and there is a conflict on my unit where the inner bolts to the outer. I have 13" wide motor mount bolts on my flywheel housing and the y pipe connection is different. after looking things over carefully we are going to use the new to me outer transom mount and epoxy one of the bolt holes that is just a little too close to the exhaust opening but this leaves us 4 bolts/studs placed pretty evenly around. I would have preffered changing all but other conflicts just kept popping up. exhaust, flywheel housing, steering-shift linkage. I have a lot of respect for the opinions of Don and Bondo and many others but after spending some looking this over we still have more bolts going through to fasten than if we changed to the other y pipe connector. anyway, good luck and take pics of how your ring works on the old housing. I didnt evenconsider as I had some corrosion around the flange for the drive bellows but didnt know the new style ring could be fitted to the old style housing.
L8-Again
The manual can better explain all the differences in MC and Alpha. I am using manual "4B Transom" that I downloaded from the 'sticky'. Pages 4B-1 thru 4B-6 describe the differences and that the replacement gimbal ring and bell housing are used for pre-alpha and alpha, like a universal replacement of sorts. It made it easy for me to decide to replace only the bell and ring for my situation. I will eventually get to the outer/inner transom replacement but that can wait for another year and a few more dollars saved up!
L8-Again
Spent the last two days putting things back together. <sigh> Didn't get as much done as I wanted. More parts on order. Wanted to share some of the 'hitches' that mixing and matching pre-alpha and alpha parts.
A word about drilling 1 1/8" holes in transom to remove gimbal ring. I will NEVER do it again. PITA! But, it did work. The used Alpha I gimbal ring I purchased slipped in perfectly. The new (used) swivel shaft is tight and I have confidence that it will last a long time. New trim/tilt assembly installed. Actually they are still just hanging there! And I found out where the previous owner stored all his grease. The cavity where the steering arm is was filled with it!
Wednesday gone. . .:facepalm:
Started the alignment process and wanted to get bell housing installed. Several hours later and many, many temptations to start another alignment thread I finally got it. When I thought I just had to ask questions I searched this forum and got my answers. Here are the problems I had: First, it took me a good hour to finally figure out how to 'manipulate' the new gimbal bearing so the alignment tool would actually enter the coupler. Ding, ding, ding, ding, ding! (I think Don S. posted something that finally made sense to me: The gimbal bearing 'gimbals' or moves in the vertical plane which, in turn, aims the alignment tool to the sweet spot of the coupler) The rubber mallet I used saved my hands by using gentle, but firm, swings so I could see the movement of the bearing. Dabs of grease on the end of the tool helped me determine which way the bearing needed to me moved. I spent a good 2-3 hours moving the front engine mount adjustments up and down trying to get the alignment tool beyond 1/2" into the coupler. I have an old drive shaft with out the u-joints and I was able to insert it all the way just fine. Climbed inside and felt around inside the coupler. I felt a small ridge that I suspected was causing the alignment tool to catch on and I did not want to force it in for fear of not getting the tool back out--as has happened to someone on this forum! I removed the gimbal bearing. After cleaning the coupler I was able to get the alignment tool to depth. Gimbal bearing re-installed. Firm mallet blows, a few more motor mount adjustments, and BINGO! she slides in just like the video in the Sticky alignment process!:D
I had some more work to do on the bell housing. I made my own shift cable socket for $5 (don't remember who suggested welding a nut to a deep 9/16 socket but that's what I did so thank you), and ground the sides down to make it thin walled. The Alpha I bell housing uses a 3/4" water hose and the pre-Alpha uses a 5/8". I had thought about using the Alpha I sized hose (3/4") with the thru-transom tube and then I would not have to change the bell housing connector. But where the 5/8" hose goes around the gimbal bearing in the pre-Alpha there is a raised portion that would cause a wear point or pinch point on the 3/4" hose. I thought I would just grind it because that is all the difference I could see between the Alpha and pre-Alpha in that area but decided against it. Bought a 5/8" hose nipple to 3/4" pipe thread fitting and put it in. I had thought I was going to have to special order something because the first plumbing store I went to (plumbing is all they do--fairly large warehouse) told me that no one makes a brass fitting like that, they suggested using a bushing, which I wasn't willing to do because that would put the nipple closer to the transom and may cause a wear problem. I found one on the shelf at Home Depot, which was my 3rd stop.
Thursday gone. . .dinner bell rang and I relaxed the rest of the evening. Have to work 36 hrs this weekend (3 12's) so I will attack again on Monday.
Thanks to all who have contributed to my knowledge! You know who you are!:cool:
L8-Again
Project is complete!!!:D:D:D
Used Alpha I gimbal ring and bell housing work great on the Pre-Alpha transom. And the SEI unit I purchased 2 1/2 years ago mounts on great as well.
I did update the shift shaft bushing and seal and kept the exhaust boot that was already on the transom.
In my effort to save money I mistakenly purchased GLM bellows.:mad: I have read that OEM is the ONLY was to go and that is what I wanted to do for the lower shift cable and the bellows, but I made an ordering error. I got the OEM cable so at least that one is good!
I removed the exhaust manifolds to check their condition. Found some rust in one of the exhaust ports.:facepalm: An expense that I did not want this year! I was able to get both riser elbows for $120 and one of the manifolds for $99, all new Sierra brand. Had to pay full price for the other manifold, though. Used OEM gaskets for reassembly.
Alignment was a challenge but it is good.
Rustoleum rattle can paint chips too easy for my taste, but it sure shines!
Should be able to splash next week!!:)
