gimble bearing
mustang
I just purchased a 1975 sea-ray boat with 302 ford engine that has a bad gimble bearing,I have never worked on a outdrives before but,I'm a auto tech.To replace the bearing do I have to remove engine???? I removed the out drive and shaft,is this suppose to be clean and dry????? any help or advice would be greatly appresiated :confused: :confused:
Trent
Re: gimble bearing
NO, You dont have to remove the engine. And the splines should be greased with marine grease. Also grease the u-joints. Check this link out, it should help you with your gimble bearing. Gimble bearing replacement<br />And for parts check this link. Bearing
