Glastron tandem axle boat trailer question
TXGlastron
Hi all. I have a Glastron trailer that came with my boat. It's a tandem axle and I need to replace the wheel hubs, bearings, etc. I'm uncertain on the exact replacement parts I need. Is there a website you would recommend to lookup this trailer and get the correct parts? Thank you.
Most all trailers use the same bearings, races and seals. The only difference is the load capacity which determines sizes of the bearings etc.
Go to etrailer, that have postings showing sizes of bearings and stuff based on load and spindle size. Once you know what the sizes are, then look all over to compare cost
Lou C
other good sources are:
Eastern Marine
Trailer Parts Depot
Contact glastron with your trailer VIN for a parts breakdown or do research on sites listed above
