glastron v162 futura project
Baylinerchuck
No need to let it completely dry between primer coats. I would think you would need to let the primer completely dry prior to spraying the top coat.
Woodonglass
Honorary Supreme Mariner
Process...Light coating of SE primer on ALL bare aluminum spots, 5 minutes later first coat of Bare Metal Primer. 30 minutes later 2nd coat of Bare metal primer. 2 hours later light wet sanding of primer using 220 grit. Wipe down with acetone and 15 minutes later shoot first coat of Paint. Rattle can is NOT ideal for a long lasting paint. If you have a compressor, a cheap harbour Freight HVLP gun and some Rustoleum Pro Oil Based paint with some added acrylic enamel hardener will give you a Much Longer lasting finish. If you use rattle can then you have a 30-45 minute window between coats of paint. If you use the Oil Based paint with a gun you should shoot additional coats within 1-3 hours.
diveplane
will continue the project a little more as i have purchased a near lake ready boat now, have a buyer for this project now.
everyone helped us here thx guys great community.
