glenn
redhatsuxx
90hp 1990 mercy with low high speed rev in neutral i have the shop manual and just done a compression test on all 3 cylinders 130, 128,130 psi all good within tollerance rev max currently only 4500 correct should be 5500 ish wheres my problem?
achris
More fish than mountain goat
Re: glenn
Let's start with some punctuation... That lot up there is hard to read....
So, the problem is that you only make 4500rpm at Wide Open Throttle, yes? Try a smaller pitch prop...
Chris..........
achris
Re: glenn
In neutral, it could be that the lever will only open the carbs enough to go to 4500... Not a valid test anyway... What do you get on the water, in forward gear at full open throttle? You should be making 5000-5500....
Chris........
JB
Re: glenn
4500rpm with no load on the engine is an invitation to disaster. Adjust the neutral throttle stop so that it won't go over 2,000 in Neutral.
achris
Re: glenn
JB,
If he has the standard Merc control box for that engine, there's no adjustment for throttle in neutral.... Just requires operator attention...
Chris.......
JB
Re: glenn
There is no neutral throttle stop on the engine? ACK!!
achris
Re: glenn
Nope... Is on the small tiller engines, up to 15hp, but not on the bigger, remote control ones.... Yep, you can rev them to destruction :D:D:D
Chris.........
