GLM Manifolds
haulnazz15
Re: GLM Manifolds
I believe dry joint manifolds don't tranfer water from the manifold to the riser. The manifolds and risers have hoses that cool them separately.
HT32BSX115
Re: GLM Manifolds
Yes,
there's no path for water to get into the exhaust via the riser-manifold bolt-together connection
skargo
Banned
Re: GLM Manifolds
Yes,
Thanks guys. Pretty much what I figured. So where does the exhaust go, all out the drive? Why does the water go through the exhaust anyway, for cooling only?
HVAC Cruiser
Re: GLM Manifolds
What are "holidays?"
And what are "dry joint" manifolds?
Sorry about that, A holiday is a bare spot or in this case an area that still has paint on it. Kinda like when your painting and go light in areas the paint took a holiday.
Yep it keeps the exhaust components and temperature down. My boat has a closed cooling system with antifreeze on the the engine side, the point where the riser bolts to the manifold has a block-off plate to prevent mixing. The seawater and antifreeze run counter flow through a heat exchanger for cooling. The seawater only goes through the riser and out the drive
haulnazz15
Re: GLM Manifolds
I am doing a center-riser conversion on my 351W when I get it back from the machine shop. I believe the kit uses Osco's, but I'll be sure and check the mating surfaces with a straight-edge just to make sure. Now all I have to do is figure out how I'm gonna mount the water separator and starter solonoid brackets. Maybe I can just drill and tap the new manifolds.
skargo
Banned
Re: GLM Manifolds
Thanks! I have a closed cooling system on my boat too, which I am grateful for! It has it's original, 32 year old 5.7 in it!
HVAC Cruiser
Re: GLM Manifolds
Sorry CascoBay didn't mean to turn this into the Hijack zone :eek:
Hey skargo its original in my 1984 too, I was actually thinking of making my own risers out of sch 10 stainless and a solid 3/8 - 1/2" thick mating plate to prevent any chance of leakage or even welding the passages closed at the surface on the manifolds :eek::D
CascoBay
Re: GLM Manifolds
It's all good! Keep the discussion going!
