Mark42
- Joined
- Oct 8, 2003
- 9,334
I had ordered a 10" round wood column to hide the common 4" steel column in my basement. The column was cut in two length wise so it could be assembled around the steel post. I glued it together with common carpenters wood glue. But there were a few gaps that needed filling. I thought about how fiberglass resin is thickened and used like putty to make fillets and such and it gave me an idea to use with the column.<br /><br />I mixed some plain old wheat flour in with the wood glue until it was thick enough to not run on a vertical surface. Using a putty knife, I pressed the mix into the gaps in the column. That was two days ago. It has hardened and is very solid on gaps as large as 1/16". It sands smooth and should take paint same as the wood. I decided to use the glue because I was afraid that wood fillers could shrink and show a full length "crack" and might not have the holding ability of glue.<br /><br />So far, so good.<br /><br />Just thought this might apply to any wood work being done in a boats cabin where epoxy or resin may not be the first choice of adhesive. Plain carpenters glue in a water proof formula might work well. <br /><br />Anywho, just thought I'd share...
