Gluvit Tips
lakelover
I thought I would add this to the already excellent info I found here before my first try with Gluvit. A few things I was curious about and figured out myself.
Coverage & working time:
The 1 Qt. size (2 lb.) was more than enough to do all the seams and rivets on a 15' Starcraft runabout. At 72 degrees outside, the pot life was about 55 minutes until it got too thick to spread and started clumping.
Mixing:
I actually only mixed half of it up and I'm glad I did that; I had about an ounce or so left over at the end. To mix half by weight, I put a mixing container on a digital postal scale, then turned it on to zero it. I poured 14.4 oz of the resin into the container; then repeated the process for the hardener (catalyst), pouring 2 oz. in a smaller container (zeroed the same way). Then I mixed & stirred it for 4 minutes per directions.
Working time:
I didn't know how much time I'd have when I started out, so I did all the seams first and then went back and dabbed it on individual rivets. After about 40 minutes I noticed that the thickening rate seemed to quicken. It actually was easier to see it filling in the seams when it got thicker, so I went back over them to use up most of what was left.
Using only half allows for mixing the second half later and putting on a second coat, which Gluvit recommends for "optimum" performance.
To sum it up, my advice is to follow the mixing directions carefully, and work fast!!
Good luck!
Bob_VT
Re: Gluvit Tips
Yes it is amazing how far that stuff will go. It is picky stuff and mixing is the key. You really have to mix the heck out of it. It will take almost 24 full hours to fully dry......
I just checked out one of my aluminum boats I did years ago and it still looks great!
lakelover
Re: Gluvit Tips
Actually, Bob, I think it was one of your posts that gave me the most complete lowdown on the stuff. Thanks.
halas
Re: Gluvit Tips
Thanks for the thorough detailed post. Going out of your way to share info...
samo_ott
Re: Gluvit Tips
Do you have any photos of the before and finished job? And how did it work out, have you put it in the water yet?
lakelover
Re: Gluvit Tips
Here's a shot after curing for about 20 hours. It's pretty clear as it goes on and dries darker. That's when you can really see all the places you've dripped and slopped it! I was hoping for a neater job, but trying to work fast in bright sunlight and the fact that it's pretty clear as it goes on made me miss a lot of drips.
Unfortunately, I won't have it in the water for a long time, I have a lot of other work to do first.
Glad to share the info, usually I'm the one asking questions, not so much answering them!
andyrmilwaukee
Re: Gluvit Tips
I know its been a while but does anyone know how much paint i need to get off before I apply it? I can not seem to get it all off no matter what!
