gm '95 6.5 diesel smokes under load.
wajajaja02
My 6.5 diesel only smokes when over 2k rpm and under load. other wise runs great, 22 mpg on the highway, good power. Didnt know that I should of tested it with the parking break on. now what.
Both batteries have gone bad, now too. will replace tomorrow. one has a dead short.
Bob_VT
Re: gm '95 6.5 diesel smokes under load.
How's the air filter??? Clean? I would run a shot or two of injector cleaner through it too...... I used to use ATF to clean my injectors.
wajajaja02
air new, and I ran a pint of sea foam in 20 gallons of diesel fuel on a 300 mile run down the coast from boston when I bought it two months ago.
gss036
You need a stronger mix to really clean an injector.
puddle jumper
What color is the smoke. White is coolant,blue is oil and black is fuel.
wajajaja02
hi, blows black smoke, but only when exceeding 2k rpm, with the trans and parking brake engaged, or pulling my boat. GM put a vacuum gauge gizmo on the breather hose from the air filter to the turbo, to indicate when the air filter need change, its green.
Strange that the two batteries went bad together after the first tow of the boat and this trouble became evident. bought two new batteries today, will install tomorrow.
puddle jumper
Not knowing GM that well but when they installed the air filter tell tail,they didn't leave anything unplugged did they. It sounds like an map or mass air flow sensor unplugged.
As of for the dead battery's if the charging system not working that might play a roll in the drivabillity problem.
dolluper
Injector pump a little rich ....or pump timming off
Bob_VT
How many miles on the rig? could just be getting old....................
windsors03cobra
Certainly not excessive fuel consumption if its getting 22mpg on the HWY.
Blowing a light haze is what diesels do when you load them.
You wanna see black smoke ? Check out some of the high performance diesels rolling coal, pure soot particulate coming out those exhausts. NASTY !
wajajaja02
my mechanic cleaned up the turbo, and today it ran much cleaner. still smoked a bit, more as it heated up. the hill i have to go up is a 800 ft climb altitude and a mile long, either way north or south out of town.
He feels I don t run it under load often enough to keep it "healthy"
